Mac SE/30 more than 8MB dirty ROMs?
TjLaZer
OK I have a Mac SE/30 and it shows 20MB without Mode32 running! Does that mean I have a "clean" ROM? lol
LCGuy
LC Doctor/Hot Rodder
Yes, it shows 20MB, but how much of that is free? If you have "dirty" ROMs, and MODE32 is not installed, the extra RAM will appear to have been used by the system.
Tempest
Does a IIfx rom count as a clean rom? If so, does putting it into an SE/30 cause any compatibility issues?
Tempest
phreakout
LCGuy is correct on that.
IIfx ROM-SIMMs are 32-bit clean. The only issue you'll have is a bit longer of time to startup the SE/30. Sometimes it can vary depending on how much RAM you have installed. I've heard of cases that had wait times of near 5 minutes before booting.
73s de Phreakout. :rambo:
TjLaZer
So let me get this straight. If I have "Dirty ROMs" and I have 20MB installed. Will it show as having 20MB in the About Finder menu? (but in fact only have 8MB usable until I use Mode32) or should it show 8MB until Mode32 is installed?
Dog Cow
It will show, if IIUC, that total system RAM is 20 MB, but the system is "using" the majority of it.
