jpolster2009
Banned
Bought a perfectly clean, inside and out, IIFX from a resale shop. Checked the board thoroughly for an hour, did not find a single drop of cap leakage, and none are bulging. It turns on from the keyboard perfectly every time, but when you go to special > shutdown, it goes to the screen saying its safe to turn it off. It will not shut down by itself. Before I spend another 30 to 50 dollars on a power supply, does anyone have any ideas? Should i re-install system software? Should I replace the Pram battery, it does hold time when you turn it off and unplug it. in fact it had the correct time when i purchased it. Any ideas? I would like to restore this to perfect order for my museum
