Mac ii not working
Papichulo
Im sure this is common but I have 3 Mac II motherboards 1 thats been recapped and has a soldered in battery holder. I cant get any of these to work. Are the power supplies known to fail on these?
joshc
It is common. It’s the startup circuit that is problematic on these; not usually the power supply actually.
The logic boards will all need recapping before going further.
Lookup Macintosh II startup schematic - on both Google and this forum and you’ll find lots of information from people who have repaired these machines before.
jmacz
+1 on what @joshc said.
Mac IIs require working PRAM batteries or they won't start. The power supply connector pins on the motherboard, check pin 15. When you push the power button, you should get around 4.5-6V coming from the two PRAM batteries to that pin (and onto the PSU). If that's not there, your startup circuit is not working (either the batteries are dead or you have busted traces in that part of the board). If you're getting that proper voltage on pin 15, then you can check pin 1 through 6 to see if the PSU is working.
pezter22
It is possible to "jump start" the Mac II's to bypass the startup circuit on the motherboard when trying to figure out a startup issue. I made my own using a AA battery holder (similar to the link) with the two wires attached. I soldered on some alligator clips. You just need 3v, touch the negative to any ground (I use the power supply case) and the positive to pin 15. It should boot. This will at least let you know that you have an issue with the Nand Gates in the startup/shutdown circuit.
David Cook
Why does it have two batteries? Does it need 6V for some reason?
On the Mac II, the batteries supply the real-time clock (RTC) and the soft-power on/off circuit. The real-time clock is designed to operate with a single battery, so they just connect a wire to one of the batteries for that purpose. The soft power circuit uses HC logic series technology which runs from 2V to 6V. This should also be fine for running from a single battery. That suggests something else needs a higher voltage.
There are three other connections to the soft-power circuit:
1. The VIA chip that allows software to shut down the machine runs at 5V. Having a 5V signal going into an HC chip running at 3V is not good. But, they could always have used a diode or transistor to safely permit the low signal to power down.
2. The ADB power-on key signals power-up by grounding this pin. So, no problem there.
3. That leaves the power supply turn-on signal. It must need a higher voltage than a partially-used single lithium battery can supply after a transistor voltage drop. So, yes, I would conclude the power supply itself must require the pair of batteries to turn on.
Apple improved the power-supply design in the IIcx (and future) by having the power supply produce a separate always-on +5V. This provides three benefits:
1. No batteries are needed to power on the computer. The always-on +5V powers the soft-power circuit.
2. Only a single battery is needed for powering the real-time clock when the computer is unplugged.
2. Current from the single battery for the real-time clock is not needed when the computer is plugged in, because the always-on +5V supplies power to the real-time clock. This allows the battery to last longer.
- David
68kPlus
- David
Right! That's really interesting, and mildly annoying, as it makes for another failure point.
Still really cool though
joshc
Yeah, when these battery bomb it’s like someone set a nuke off in there. Two Maxell batteries makes for some real destruction.
