TimeThrough
New member
I do not know if anyone cares but I found a Mac & Frost for a decent price and seems like it is a later version. The only problem with it is just that someone over tightened the screw hole and cracked it but if you screw it slow it will be fine, in the last image there was something broken off from the only image I found off the internet does not show much of what it seems like just a plastic dot, and there is just random small indents like seen in the fourth picture but none of that can be seen without looking at the bottom. It would be cool if I could somehow fix what ever broke off though it is also on the bottom so not like you can see it and it does not go through the plastic. The only thing is that you can kinda see in the sixth picture that the fan is held down by plastic buttons so you can not replace the fan and it kinda makes it harder to clean and it is not possible replace. But in all though I like the Mac & Frost design better than the Kensington and its clones and it is about as quiet as it gets with the original fan. Then there is a unused modem spot I would get the stuff to set it up but since it is twenty twenty four I do not have a use for it unless I find a Mac Phone but have not found one yet. Everything works fine I have replacement capacitors coming and a new fuse. P.S these pictures were taken before the cleaning.
