Little bit of Bootblock editing
IPalindromeI
...people don't seem to realize the potential for bootblock editing - you can boot directly into whatever application, no Finder needed.
Here' I've used Browser - it kinda works, but you can't open applications and many menu entries don't work. It's a start though... maybe some extensions would help it.
onlyonemac
Just name the application "Finder", change the type and creator codes to those of the original Finder, pop it in the system folder, and restart.
Much simpler :) .
onlyonemac
I think that was an extension.
But then, how did it manage to ask for a password when you started with extensions disabled? Maybe it was, you know ;) .
