Hi, all,
I've had the chance to get a few different drives into a Quadra 630. Outlander was right about the Quadra 630 supporting drives larger than 128 gigs, which I'm certainly happy about. I suppose it makes sense since the Quadra 630 came out several years after the Amiga 4000 and 1200, which do have the 128 gig limit on their IDE.
However, Drive Setup and other utilities only see 128 gigs no matter the real size of the drive, and I couldn't find any way around this in Mac OS on the IDE bus at all. Outlander - I'd love to hear if you have had any luck with this part. In order to partition my drive using the full size, I had to use a SCSI Quadra with a SCSI-IDE bridge, then install the drive back in the Quadra 630.
In NetBSD, though, the full amount of the drive is seen and can be used:
wd0 at atabus0 drive 0:
wd0: quirks 0x2
wd0: drive supports 16-sector PIO transfers, LBA48 addressing
wd0: 698 GB, 1453521 cyl, 16 head, 63 sec, 512 bytes/sect x 1465149168 sectors
wd0: drive supports PIO mode 4, DMA mode 2, Ultra-DMA mode 5 (Ultra/100)
This system is happily cvs'ing and compiling away, soon to be set up to compile NetBSD's pkgsrc software for softfloat m68k ports (which is particularly useful for LC040s which can't emulate an FPU properly). I even managed to fit a QuadDoubler onto the motherboard:
http://www.ziaspace.com/~john/q630_1.jpg
http://www.ziaspace.com/~john/q630_2.jpg
http://www.ziaspace.com/~john/q630_3.jpg
It's turning out pretty well... Next, I'd like to find a Quadra or Performa 631 motherboard with two SIMM slots so I can have a machine with 196 megs of memory...
John
