Scribe
Apologies if this has been addressed. I've searched through the posts and didn't find a solution to my particular issue…
I am looking for a way to mount a SCSI2SD (v5.1) against the front of an SE so that the SD card can be swapped in and out easily without opening the case. Most of the solutions I've seen have the board mounted too far back or facing backwards. I know that there is a mount which uses the expansion slot in the back, but I already have an ethernet card in that slot.
I assume the access would have to be through one of the floppy slots in the front.
