iMac G3: HOT!
Theretrogamingroom
I recently bought an iMac G3 to give to someone. When the computer is on for a while (About 30min-1hour), the backside gets VERY hot (Like touch it and it burns, especially if you are touching metal). I have already modded it by installing an internal fan to help keep it cool, but it still gets pretty hot. I had to set an external fan behind it to deal with the temperature. Even though the bottom side got cool with the fan, the top half right around where the clear vent is still hotter than it should be. I can feel the heat from inside of the computer without even touching it just by having my hand over the vent.
What more can be done about this?
BTW: The heat seems to be coming from the CRT, although other parts are affected as well. When I unplugged it, the tip of the power cable was hot as well as the metal prongs on the computer. The motherboard seems to be doing fine. The HD/CD drives are slightly hot, but not as bad as the screen.
Any help would be appreciated.
Thanks
MacJunky
This is normal, you can thank apple's jobslogic.
(though living in texas does not really help much :p )
Bunsen
Admin-Witchfinder-General
Make sure the bottom is propped up with the fold-out foot/handle thing under the front edge, to let cool air in. I would also suggest propping the rear up with a book or a block of wood or something, without blocking the vents. The more easily cool air can enter at the bottom the better.
LCGuy
LC Doctor/Hot Rodder
Thats completely normal, this is why so many of them have failed over the years. I remember doing work experience at an AASP back in the day, we had a lot of them come in for replacement of the PAV or Down Converter board, mostly due to overheating.
techknight
take it apart and put a lite-up fan in the handle area. Not only it would look cool, but it would also be cool.
