I got two early 2000 iMac G3. Both of them are in different need of repair. One powers up perfectly but has a cracked case and a scratched screen. The other one looks way better but does not power on. I could make one good machine out of the two but rather would try to repair the non-working machine. The machine does not power on. Only a light scratching noise from the speakers while I press the power button. Nothing else, no screen output, no chime.
According to https://de.ifixit.com/Antworten/Ansehen/173281/its+not+powering+on I measured voltages on the logic board. On J9 I get 5V as it should be. On the power connector to the PSU I get nothing (as the machine does not power on). The PSU looks okay regarding capacitors. No visible leakage. I did not disassemled the machine further to take a look at the analog board. Which is more likely to cause such issues?
Another side question: Which of the two machines is the "faster" one? Both have a 400 MHz CPU, but the difference is probably the graphics card. Or is this just different labeling done in different factories.
"IN/400/64/10/CD/128P/56K" vs. "IMAC DV AB 400/64/10G/RAGE128PRO4XL/512K"
