IIx Power Supply on the Fritz?
ajacocks
I have a IIx that I have been restoring to working order, and it's mostly working well. I've got it currently configured, as follows:
8mb RAM
9gb UW SCSI Seagate Barracuda
Radius PrecisionColor Pro 24X
FWB JackHammer
Radius Rocket 33 w/8mb
ProAudio Spectrum Mac
I'm pretty happy to have all of this, but my power supply is starting to show signs of it's age, I think. The IIx now only stays on while the power key, on the keyboard, is held down. I've heard it mentioned that this may indicate a bad power supply, but I'm not sure. Both of my PRAM batteries show 3.6v, so I don't think it's them.
Any thoughts?
Thanks!
- Alex
techknight
grab a multimeter and watch the rail voltages. do they sag beyond tolerance? if so then i would say the power supply may be at fault.
patatas
I tried two different power supplies but with not luck.
Eventually had to swap out the capacitors to get it to stay on !
Byrd
Hi patatas,
what capacitors did you replace - was that in the power supply or on the motherboard? Have a similar issue with my IIfx - only powers on with the power key held down.
Thanks
JB
TylerEss
I seem to recall that the two soldered-on PRAM batteries on the 6-slot II-series Macs will cause this behavior when they're flat.
Am I right that they are what you replaced patatas?
24bit
I had a similar issue with my MacII about ten years ago. Soldered in two new batteries, but that did not help.
I located the problem in so far, as the trickle voltage from the batteries did not reach the psu.
Starting the psu with a seperate battery did work, but I gave up there. :-(
