IIci ADB Issues
saybur
I've got a troubled IIci and was hoping some wise soul here might have a good idea about what to try next.
This system boots up but does not register anything over ADB. Shaking the mouse during or after startup does nothing, nor does typing anything on a keyboard. After the machine boots, pressing the interrupt brings up the usual prompt.  This keyboard and mouse are my bench ones I use for testing machines and work on other systems. I verified that 5V is present on the ADB power pin and ~4.7V (or something similar, I don't quite recall) is on the data pin. Soft power from the keyboard also works fine.
I hooked up my oscilloscope to the data line to watch what it was doing, and it is... kind of weird. The edges are nice and clean but the data doesn't seem to make any sense: the normal sync, command byte, and stop bit are all there, but the system keeps sending a $FF command byte over and over again, long after the computer has finished booted. After shaking the mouse during bootup I can see it stretching the stop bit to do a service request, but the system never responds, and just keeps spamming $FF. The timings look OK, including between the transactions.  It's been a while since I worked with ADB, but I'm pretty sure $FF is an illegal command - Inside Macintosh says the addresses go through $E, and do not include $F, for what that's worth.
To get a comparison I hooked up my working IIci and snooped ADB on that.  It started by sending $1F, which makes more sense, and I did see a longer transaction when it probed the mouse without getting a service request.  The mouse worked after the system booted up.
This system came to me untested and I've done the normal work done on it:
  • I've replaced the existing electrolytics on the logic board, scrubbed affected areas with IPA, recapped, and dried 48 hours. There was more green rust than normal on several areas near the caps, which was also cleaned up.  This includes the area near the ADB chip, which was quite green, but I'm fairly confident it has been extensively cleaned.
  • The existing Astec PSU has been swapped with a known working Astec from the good IIci for testing. In operation it is showing 11.9V and 5.1V on the main rails (this is not a recapped unit, but I do have caps in the mail for both power supplies and intend to do that later).
  • HDD, expansion cards, and cache card have been pulled. I tried this with both the memory that came with the system and other, known-good SIMMs.
One other thing: when cold booting today, I did get a boot chime, followed a second or two later by death chimes and a black screen. The system was OK when rebooted. I left it off for 15 seconds and tried again, and the same thing happened, but the time between the boot chime and the death chimes was much longer, like 10 seconds or so. It didn't do it again afterwards, and did not do it before when I was first testing this machine. This prompted me to swap the memory with good sticks and leave the computer alone while I ate dinner.  When I came back, same basic thing: boot, then death chimes, then it was OK after repeated startups.
Sorry for the long post, and I appreciate everyone who took the time to read it.  If you have an idea, feel free to fire away.
Elfen
Right behind the ADB Port is a Bournes Filter IC.  It's simply a pass-through resistor pack with a transistor (?) in it. They blow out easily. Look through Dead Mac Scrolls (you can find the pdf online) to get the proper IC number and order it and replace it.
This Bournes Filter is the scourge of all the Macs from the SE to the early PPC machines. they use the same chip on all the machines. Plugging and unplugging the keyboard and mouse will blow them dead. Looking at it the wrong way will cause them to die too. They are also sensitive to static so wear a Anti-static wrist band when you replace it.
trag
The 4120 series is a resistive/capacitive filter, not just a pass through resistor.    But Apple appears to have used a small variety of parts in this position and reportedly some of them were purely resistive.
View attachment 601.pdf
saybur
Awesome, thanks to both of you for that information. I'll take a look and let you know if that did it.
