bubbleman7546
first car thats going to be a running project. as far as i know, it's a 65 and i'm picking it up next week!! gonna be a fun project!! ;D ;D
Actually, it's the cloth tubes that break the rubber inside that springs leaks. If it happens in the engine compartment, it will cause a fire when it touches the engine block...It's really people replacing the fuel filter and not replacing the clamps on it with new ones that apparently cause fires. They were one-time deals. My VW is fun to drive. Only a few more months till I'm legal to drive it though![]()
Custom paint job with flames with Rammstein cranked. Feuer Frei! Haben sie ein Deutschen playlist?.Wagner, you mean?You'll have listen to Kraftwerk.
We are living in a Amerikaaa, Amerikaaa, dum dum dummmmm......Custom paint job with flames with Rammstein cranked. Feuer Frei! Haben sie ein Deutschen playlist?.
Why would it destroy the engine if the belt breaks? You mean because the fan would not be spinning?Also, make sure the belt to the generator is on there. That also goes to the engine fan. If that belt breaks (or you suspect it has), pull over right away! that will blow out your engine faster than you can blink!
Exactly.Why would it destroy the engine if the belt breaks? You mean because the fan would not be spinning?Also, make sure the belt to the generator is on there. That also goes to the engine fan. If that belt breaks (or you suspect it has), pull over right away! that will blow out your engine faster than you can blink!
I'm guessing not. Due to the design of the engine already in there it would lack the necessary water channels in the head and block required to hook up a radiator and water pump.Could you add a radiator?
