How to boot Apple II Desktop/Mousedesk off of a virtual drive?
tanuki65
I am using A2CLOUD as a hard drive for my Apple //c, and I wonder how to boot Apple II Desktop (which I have on the virtual drive) up. When I type
-DESKTOP.SYSTEM
it just loads a little, then crashes.
Edit: Also, how can you run AppleWorks?
david__schmidt
The serial drive driver occupies some memory that the deskop clobbers.  So that's why that approach won't work.  You'd have to find/make real floppy disks to run either of those desktop programs (or AppleWorks, for that matter) from the IIc - or get one of the SmartPort devices that have been coming out lately.
tanuki65
Aren't you thinking of VSDRIVE.LOW?
Edit: Also, is there any way to load MouseDesk from floppy, but then have virtual drives to launch programs from (through MouseDesk)?
tanuki65
Also, could you give me a list of software that is VSDRIVE compatible? And I thought VSDRIVE loaded in in place of the floppy driver. (Which MouseDesk doesn't overwrite.)
david__schmidt
If you can load MouseDesk from floppy (which I don't know, I've never used it) then the version of VSDRIVE that overwrites the floppy driver ought to work (which is what I think A2CLOUD uses).
I don't have a list... if you're overwriting the floppy driver, then any ProDOS software ought to work.  You'd have to ask Ivan specific questions about how A2CLOUD behaves and what to expect; I'm honestly not an expert there.  I only supply the driver. ;)
