Help needed for Apple Lisa PSU Transformer 120VAC
Greniu
Hello all. I am trying to fix one of my problematic Apple Lisa PSU 120 VAC, 60 Hz, 1.2 Amp, 150W which isn't working.
First thing that came to my notice is a resistance of the Transformer (T2 in the attached schema).
I have compared it with the other working PSU 1.2 AMP but dedicated for 220-240 V~, 50 Hz, .7 A, 150 W.
I have measured the resistance with multimeter between 2 and 5 pins and it shows OL (open line).
On the working one ( 220V version PSU) it shows 1k Ohm. So it looks very suspicious for me.
The question is: Is it normal for 120VAC version? Can anyone help me to confirm and measure their T2 resistance values (between pin 2-5) ? I am especially interested in 120VAC Transformer version measurements.
I have also noticed difference in serial number of T2 transformer for 120VAC version and for 220V version.
120VAC version has EXCEL Transformer with number 157-0015-A. 220-240 V~ version has EXCEL Transformmer 157-0016. So this might have an impact?
I am atttaching pictures of my suspicious T2 from Apple Lisa PSU 120 VAC, 60 Hz, 1.2 Amp, 150W.
Thank you
Greniu
Can anyone on this forum measure the value of resistance between 2 and 5 pins of his working T2 Transformer? This is Apple Lisa PSU 120 VAC, 60 Hz, 1.2 Amp, 150W. Thanks 358148164_3317899385187861_5290603575356670641_n.jpg
