I have full Q51 schematics. They're NOT hard to find. Q51 was definitely a G5-based design.Also notice how everything denoting it as a Q51 machine has been crossed out. I might (and there is a slim The engineer you bought it from did say it was never released, so I'm still in the G5 group.
Schematics for the logic board for a G5-based PowerBook prototype exist, dated Feb 23, 2004. I'm just going to say they're out there if you look under Q51. Power consumption numbers can be found on the third page, and they are absurd at 113W. My guess was that they went through the trouble of designing the logic board so they'd have a design ready to go as soon as lower-power G5 chips materalized. Except, they didn't. The design is roughly similar to an iMac G5, just with laptop-specific things like CardBus, battery charging, etc.It would be interesting if there ever was a prototype with a G5 in it. This one looks like it was probably a part of some sort of feasibility study, and possibly was developed in parallel with or immediately after any sort of G5 prototype would've been built. The results of this study are probably what determined the need for the Intel switch.
That being said, a similar prototype with G5 CPU(s) most likely exists, it's just that nobody's found it, yet.
c
It is indeed a 17 inch. What's next I keep looking for more crazy stuff. I'm going to see if I can figure out what's up with the Q51 sticker and where that board went }It is a 17" model correct? Well... what now?
Well I'd assume because the power adapters fairly large as well as the engineer saying that it had stability problems. The charger is about the size of the first MagSafe charger. That was the largest they were "allowed" to build it and getting enough power to those chips with that size limitation proved very difficult. The engineers would use beefed up power bricks with adjustable voltage so they would run stable. When they were just running off the bricks it was iffy. I'd assume that was a major factor why this never made it to the market.Since we had the PowerMac G4 DP, so why not the PowerBook G4 DP. hap?
Core Duo wasn't available until Apple used it - they were the launch customer with the first Intel iMac in January 2006! If this is from 2003-2004, this significantly pre-dates the Core Duo. If it actually dates from 2003, it even predates the Core Duo being on a roadmap, as Intel hadn't yet committed fully to increasing core count as a means of speeding up systems. And in the Intel world, dual-socket systems were still in the realm of higher-end servers and workstations, not consumer machines. Apple was basically the only company that was selling dual-CPU systems to "consumers" (albeit high end ones) with the dual-CPU G4s and G5s.makes sense… why they were so excited when the Dual core… Core DUO was available!!!!
they were like yeah … its INTEL bOOO… but its FAST!!! woooO!
and its dual core Wooooo!
and its fairly energy efficient Woooo!
But sir… we will probably piss off most of the MACHEADS going to INTEL you know…
yea… you are correct… but WE HAVE NO OTHER OPTIONS!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
lol
Right in the thick of it baby. I'm always up on CL, and eBay looking for stuff. Honestly you just need to know what to look for. Both of the prototype Macintosh Portables I bought were not listed as such. I just know what to look for and knew what was up. Pick em up cheap, confirm my beliefs, add a 0 and make it a part of the mini museum.I gotta ask, are you in the Silicon Valley? I ask because you find some the craziest and rarest prototypes no one ever thought would have existed.
Heh - because it has webbed feet, right? A real puddle jumper.DVT LCS, and it's a QUAD CORE! The code name for that project was DUCK.
