Guide to replacing EPROMs with EEPROMs
eharmon
I much prefer EEPROMs over EPROMs; when tinkering the constant cycle of waiting for some chips in the UV eraser just gets annoying. But every time I need more chips I forget what the equivalents are, so I finally took my random notes and compiled it into a single page you can use to find what chips to replace your EPROMs with:
Let me know if you have any suggestions! I tried to cover the most common 27C DIPs found on Mac parts to start.
motosega
What about 27c010, 27c020 and 27c040?
I never found direct replacements
27c040 EPROM and 39sf040 EEPROM have a slightly different pinout, which will require some bodge wires...
eharmon
I definitely need to get to adding the larger sizes. For a 27C010 you can use a Winbond W27C010 or SST SST27SF010. Generally both of those lines are compatible with larger memories.
IIRC all the 39SF line is just a bit off JEDEC, unfortunately.
eharmon
Since I was real bored last night, I went ahead and updated to add the larger DIP EPROMs.
As far as I am aware, below 27C64 there are no EEPROM/Flash replacements, so I haven't bothered adding them.
@funnymike
You might want to pay attention to this thread.
Note winbond do some 27C010 chips that are electronically erasable - this makes them easier to handle because if you need to erase them, you don't need a UV lamp.
Something like this :
