Actually, it was the Claris connection that led me to find the piece via Google, as I have been looking into the implementation of Publish and Subscribe in Claris software. OpenDoc is in some ways an extension of that concept: you don't need an outliner in MacWrite Pro because you have one in Claris Impact, which you can subscribe to in MacWrite; by a similar line of reasoning, you don't need a monolithic office suite because instead of having the capacity to do 500 things with your machine, you only need it to do 40 things, which multiple software packages working conjointly on a well-defined platform can provide more elegantly, and perhaps more powerfully, than only one. Mix and match would thus be better than one-size-fits-all.
The trouble with using the modular approach of Publish and Subscribe or program interoperability on the level of Claris stand-alone titles like MacWrite or Impact or Draw, etc., was that it would have cost a fortune in the 90s to have all the pieces in place so as to do what you needed via Publish and Subscribe. These days, you can buy the titles for a song; those days, you'd have needed to drop a grand or more to acquire the suite. Presumably OpenDoc was intended to address that problem, by opening up possibilities to niche companies, and the provision of office software to vastly greater competition, including Shareware outfits, which would be writing small software packages to do small things. Brilliant in concept - and no wonder the high-ups at Claris didn't like it.
I find these lost technologies in vintage software rather interesting, and their failure rather sad. In fact, the software is as interesting or more than the old hardware tends to be. After all, once you have your IIci or whatever up and running, what then? Well, then you have to give it some softwre to run.
As OpenDoc more or less died a death (though I still "use" it 24/7 courtesy of an ASIP 6.2 server that I run - up to v. 6.2 it relied on OpenDoc for certain administrative functions), I plan to explore what Publish and Subscribe can do for me in Claris software over the summer. I still like the old Claris titles better than anything out today.
