Garmin iQue 3600 GPS/PDA
coius
Runs Palm OS 5 I think...
My dad could never get it working (found out, he didn't get the antenna all the way. I understand why, it doesn't want to go all the way up without it feeling like you are going to break it)
It's from 2003, and the palm software was never used. So the Maps are from 2003, and I found out, the 2009 Software is $75... Gonna try to get that somewhere else ;)
Anyways, It works fine. With Map software from 2003, anything other than street data out to 210th screen is useable, but anything beyond that, it's worthless.
I have an Interview with Xerox through a company called "ManPower" which is an employment agency. So it will come in help getting out there, as well as it will be a great use if I need to use it to get to a location while working with Xerox.
I hope I get the job. I would be doing what I love best. Fixing stuff :)
Might get me away from working with machines that I can never seem to make some people happy...
It will also give me extra income :)
The GPS works fine, and so does the PDA part. It's almost in new condition (my dad put a screen protector on it, which has some grime around the edges since it was sitting in the open) and was probably used a total of maybe 100 hours and then left.
The battery is pretty good I would say, but I wouldn't leave the GPS on all the time.
Since I have no power outlet in the car, I am not sure what I will do to keep it powered. I guess I could use some of my Gell Cell batteries I got hanging around. Put one of those under the seats and I should be good :)
coius
Believe it or not, I am typing this post from the garmin docked in the cradle with a piece of software called "The Missing Sync" The main problem I have is that the network connection keeps timing out :-/ Oh well...
