Me thinks someone missed out on the subtlety seminar...Intel. I'm not even sure why a G5 is still a consideration at this point. Unless you just really like the PPC platform, 2 internal HD limit, purchased obsolescence, and knifing yourself in the face, an Intel machines is the way to go.
I do agree with you. I was just making a funny at the time.that may very well be, but G5's are still not cheap and considering how much more powerful even the first-gen 32bit Intels are (unless you plan on getting a last-generation G5, which are even more expensive), a used Intel Mac is just a more practical purchase at this point.
Now, if Classic support is a must and you don't mind being stuck with Tiger (which is a perfectly fine OS in its own right), then a G5 is obviously your best option.
But realistically what do you just have to run under classic that you cannot find a free or open source alternative which is OS X compatible for? The Apple software market is flooded with thousands of excellent free or shareware utilities which in many cases are better for some things than their counterparts from corporations (insert Linux fans).
Alternatively, you could install a CPU upgrade in an early model G4 like my Sawtooth (such as the MAXPower G4/7448), and get all the compatibility of the pure classic Mac OS at much faster speeds.I do agree with you. I was just making a funny at the time.that may very well be, but G5's are still not cheap and considering how much more powerful even the first-gen 32bit Intels are (unless you plan on getting a last-generation G5, which are even more expensive), a used Intel Mac is just a more practical purchase at this point.
Still, even the first-gen Intel Mac Pros and iMacs tend to be quite pricey compared to the G5 Macs. But yes, if Classic is a must then a G5 would probably be best. Then again, a late-model G4 Power Mac would serve you just as well for a lot less, or just find yourself a classic Mac that can run Mac OS 9 and move to an Intel Mac. The cost of a G4 or earlier to run OS 9 shouldn't make a dent on the prospect of purchasing an Intel Mac.
The Mirror Door Drive G4s spanned the boots-OS9/Doesn't-boot-OS9 transition.I think the last gen MDD were the non OS 9.Not even all the G4's could boot into OS9 directly, you just had classic support under OSX.
I believe the other one is Delphi.There were also two different types of cooling units, one by Panasonic and one by...somebody else, i forget who, the one by Panasonic actually works brilliantly and has a much lower failure rate than the other. Everytime you hear about a G5 catching fire or leaking, its one of the earlier, crappier designs with the O-rings i mentioned earlier.
