Mac128
The only thing I can think for a clean S2.1/F5.0 HD20 v1.0 disk not working on your setup is that whatever system you have installed on your HD20 was formatted and setup with v1.1 tools and S3.2/F5.3 which is somehow incompatible with the older version, especially if you are using a more current system on your HD20 than 3.2/5.3.
As I have speculated, System 2.1 may be a patched MFS system that relies solely on the HD20 INIT to patch the system. I'd love to see a Hard Disk 20 manual to see how Apple implemented this for the user. Under that assumption System 3.0, then is a fully HFS aware system that by 3.2 (in a short 5 month span BTW) probably works somewhat differently. I need to compare all of these systems to confirm my theory though.
Curious to see what happens with the ResEdit HD20 INIT. At best, I can only hope it will mount the HD20 and allow you to see it on the desktop, but I would not expect the .Sony driver would hand off the system to it. Chances are, without the "TFS" resource, your Mac won't recognize the HFS format on the disk and ask you to initialize, in which case that would tell us, it sees the disk. Try three different hacks:
1. "TFS" & .Sony resources ONLY (may allow reading HFS without system handoff)
2. "Dispatch Kernel" & .Sony ONLY (who knows?)
3. .Sony only (should be MFS read only)
Something I am also curious about ... when you loaded System 2.1/Finder 4.1 with the normal HD20 INIT and then inserted a known HFS disk, did the extra pixel show up? I'm wondering if that's a feature of the Finder or the System.
