uniserver
So i am here tearing into this Macintosh Classic.
Pulled out the A/B board, Had to re-cap it, Screen was wavy, HD would not spin etc. etc.
Anyways, Replaced all the caps following my recent post. viewtopic.php?f=7&t=21471
And, Everything now works great!! HD fires right up!
Screen is Solid and Bright.
Only now there is this line. Basically after a few hours of Probing... testing...
I had a hunch that the issue might be caused by external interference.
Whenever I test Compact macs, I always test them with the rear can off.
So I put it all back together, tightened the screws up.
Then fired it back up.
And sure enough this " traveling line " syndrome I was experiencing had went away.
(The line was slight and it would travel from top to bottom of the screen all the way across).
Kind of irritating, because I wasted about 2 hours trying to track this issue down.
At-least it works now.
