Floppy wont eject
I haven’t opened the mac yet but it makes a whirring sound.
The drive bezel is the plastic bit of the case where the slot is to put disks in. You don't need to open the case to see it. It is on the outside.
It either has two "lips" or the top and bottom are mostly straightish.
Sounds like your eject gear gave up though. People sell them on ebay.
joshc
Broken eject gear, most likely. What @Phipli is basically asking is, which drive/machine is this? There were lots of different floppy drives used over the years on Macs, with a few differences between them.
Yes, with the complication that different drive types were used in some machines so I can't just ask "which model computer".
joshc
Yep, those need a lot of cleaning and correct lubrication to work properly, can only be done by taking the drive out of the machine and removing the cover.
techknight
unless it was an upgraded 512K to 800K setup. in which case it has a regular eject mechanism and drive.
olePigeon
The grease on the 400K drives has likely crystalized and hardened. It will take some significant cleaning, but as others mentioned, it's very doable. Just tedious to loosen and remove all the old grease. After it's been lubricated, the drive should be just fine. They're built like tanks.
MacTopus29
Do you have any recommendations on what grease I should use? I have WD-40 in my basement. If I can use that that would be nice but what is the best type?
