Not ignorant at all.
I appreciate having somebody review my logic and point out things I may have missed, since I'm not really thinking straight anymore.
One thing that maybe wasn't clear is that the ATMEGA isn't the limiting factor for the most part. It's the write speed of the SD card that's the issue. The ATMEGA can send 512 bytes to the card, one bit at a time, in about 1.5 ms. (Theoretical speed would be 512 * 8 / 4 MHz, which is 1 ms, but it's not totally efficient). Then the ATMEGA polls the SD card until the card says the write has completed. That takes anywhere from 0 to 80 ms, depending on the card, the write mode, and some random chance. Most of the time it's about 3-6 ms, but sometimes it's much longer. It's actually the variability that's a problem more than anything else.
Worst case a Mac is going to have... what, 24 sectors in a "cylinder", IE, front/back on a 12 sector track? ...(snip)... So, worst case, let's say our target is to be able to load or store 12k absolutely as fast as possible. To do 12k in 12 ms would require a transfer rate just about exactly 1MB/sec. ...(snip)... if we're able to add that 23ms "wait for a sector address mark" time to the 12ms step time that alone cuts our maximum required data transfer rate from 1MB/sec to closer to 350K/sec
Right. I did some tests of a 24 sector continuous multi-block write, like would be performed when flushing a track buffer back to the SD card. This should provide the best possible SD performance. On the class 10 card, the total time was normally about 40 ms, but three times out of twenty I saw times over 170 ms. With the slower class 4 card, almost all the times were over 300 ms. So the class 10 card time is pretty close to the theoretical minimum time, given the SPI transfer rate, and would probably improve with a faster ATMEGA or faster SPI clock. But the class 4 card... ouch.
If I try to fit that 24 sector write into the 12 ms track step window, it clearly won't fit. Even if I could also use the 23ms "wait for address mark" time, it's still not enough. Furthermore, the numbers 12 and 23 are from the Mac Plus ROM, and other Macs might use different values.
Is there any way at all for you to "multitask" reading and writing, IE, if you started a track buffer fill at a track step but weren't finished before you absolutely had to output a byte can you keep reading the SD in the background while handling the IWM data stream? Or, in the case of something like a format or other diskcopy operation, where the Mac might just start blasting write sectors out blindly without bothering to read a sector first, could you possibly opt to write those sectors straight away into the buffer and keep them there until you're again ready to flush them in the background?
Yes, it already does this to some extent, and I think this is where further improvements can be made. Currently it can receive a sector from the Mac at the same time as reading or writing from the SD card, through the use of an interrupt routine. But it can't send a sector to the Mac while also doing an SD read or write. I think I could do that, but I need to look into it a little more.
One encouraging note is that there do appear to be some substantial extra delays during floppy writes, outside of those imposed by the disk itself. In some simple tests, after stepping to a new track, I saw about 45 ms delay before the Mac switched to the other side of the disk, then about 20 ms more delay before the first byte of the first sector to write arrived. Combined, that should be enough time to complete the 24 sector multi-block write with the class 10 card, assuming it doesn't do one of its 170 ms "burps". But the class 4 card would still be totally unusable for this case.
To handle the burps, and possibly get the class 4 card working, it could maybe do something like:
- When a step to a new track occurs, immediately read the first four sectors (2K) of the new track from the SD card, and store them in RAM (about 8 ms).
- Begin a multi-block SD write of the 24 sectors (12K) from the old track
- After 12+23+?? ms, begin sending the first of the new sectors in RAM to the Mac, even if the SD write is still in progress. This would require the multitasking changes mentioned above
- Once the SD write finishes, read the remaining sectors for the new track into RAM.
With four pre-loaded sectors from the new track, the 24 sector SD write could take as long as 12+23+12+23+12+23+12+23+12+23 = 175 ms. Actually a little less, since about 8 ms of that time would be needed to read those pre-loaded sectors, so about 167 could be used for the SD write. That's still not really long enough to cover the longest class 10 burp, and not even close to long enough for the class 4 card.
A related idea would be to use a 12 sector "side buffer" instead of a 24 sector track buffer. Then you wouldn't have the 12 ms track step time to work with, but there would be less data, and two entire sides could be loaded in RAM at once using the internal RAM of an ATMEGA1284 (the 8-bit AVR with the most RAM). So it would go something like:
- When a switch to a new side occurs, immediately read the first 8 sectors (4K) of the new track from the SD card, and store them in RAM (about 16 ms).
- Begin sending the first of the new sectors in RAM to the Mac, while simultaneously reading the remaining 4 new sectors into RAM (requires multitasking).
- After all the new sectors have been read, begin a 12 sector multi-block write of the old sectors to the SD card, while simultaneously sending the new sectors from RAM to the Mac.
So I think that would work, but I'm getting a little dizzy thinking through all the possible cases. Like what if the new side is being continuously written, without being read first? Or what if the Mac steps to yet another new side/track after a few ms, without reading or writing anything, because it's just seeking to a different area of the disk? Or in the worst case, what if the new side is completely written with data and another side/track change occurs before the old side's sectors have finished being saved to SD?
Now you can see why I've been getting dizzy just trying to think all this through! :O
