Firmwares for Fujinet for Apple ][ manufactured by Masteries
masteries
Greetings,
Here I will upload and maintain all the firmwares oriented
and tested for the Fujinet for Apple ][ model I manufacture:
=>Firmwares suitable for REV A hardware revision (REV A is the first version of the FujiApple),
these are the same as for REV B hardware revision:
Firmware v1.1 :
https://drive.google.com/file/d/1OtIMIUGgZYRouATKP3oUh3WJIn_8th_a/view?usp=sharing
Firmware v1.0 : https://drive.google.com/file/d/16UMjHlqC_aNxAdWib7JAEvFjyfrbvfUv/view?usp=sharing
=>Firmwares suitable for upgrade REV A hardware revision
(the upgrade can be identified easily, your unit will have REV A marked at back,
but there is also a copper wire soldered between the green board and one pin of the SD card holder):
Firmware v1.1 :
https://drive.google.com/file/d/1V6FNA9Sv6qn5T3kdlYBX_zAwcGgFGrvh/view?usp=sharing
Firmware v0.5.77bfa009 : https://drive.google.com/file/d/1elNx2yRY1EcVt_S4ILmVQG2ytTgAocNn/view?usp=sharing
=>Firmwares suitable for REV B hardware revision (REV B is the latest hardware revision),
(these firmwares have the checking for the lack of one component disabled, due to this checking
is not compatible with all available versions of AHCT125 ic ) :
Firmware v1.1 : https://drive.google.com/file/d/1OtIMIUGgZYRouATKP3oUh3WJIn_8th_a/view?usp=sharing
masteries
Update with Firmware v1.2,
compiled for all Fujinet for Apple ][ hardware revisions
=>Firmware v1.2 suitable for REV A hardware revision (REV A is the first version of the FujiApple),
Firmware v1.2:
https://drive.google.com/file/d/1S16R1CJH-lCQrGdnq5kOMbn5snws0lvb/view?usp=drive_link
Firmware v1.2:
https://drive.google.com/file/d/1ffl7-1SCgafa0xo_55lc_jyOfQGvKhcX/view?usp=drive_link
due to this checking is not compatible with all available versions of AHCT125 ic ) :
Firmware v1.2:
