basically a chain of events that occurred making me think it was something more complex then what it was due to my lack of experience with the 128k 512k plus .... Floppy drives and floppy cables.
One thing I do know after an hour of going back and forth online with MCD at like 2 am EST. I decided to make a cable. What I did was cut a chunk from wire 9 and wire 20.
The other thing i had to do is remove my 800k drive that was in there because something had some how gone terribly wrong with it.
Apparently when you upgraded a 128k or a 512k to a 800k drive back in the day, the kit included a new floppy cable(yellow stripe) as well as all the other stuff, Rom, Drive etc.
If anyone downgrades the floppy drive back to a 400k drive you have to install the original floppy cable(red stripe).
Additionally, in my case, my 128k was upgraded to a plus.
For whatever reasons instead of changing the floppy cable. They just made a change to the floppy drive its self to ignore pin 9 and 20.
ok and all is well as long as you are running a plus main-board with that floppy drive.
if you slap your 128k or 512k board back in there once you have downgraded your plus, and you do not also change the floppy drive back to 400k
( OR ) cut wires 9 and 20. Bad things will happen to the 800k floppy drive, if you run it like that over a short period of time.
As long as you cut wires 9 and 20 of a red striped cable or find a yellow striped floppy cable. The 800k drive in there will still work great as a 400k drive in the 128k or 512k.
**Later 800k floppy drives such as the ones in the SE, would still need pin 9 and 20 cut in the floppy cable in order to use it in a plus.
also good news is i have replaced both network filters.
EDIT:
TO MAKE A LONG STORY SHORT. IF YOU ARE GOING TO RUN AN 800K FLOPPY DRIVE IN A 512K OR 128K, JUST MAKE SURE THE FLOPPY CABLE HAS A YELLOW STRIPE ( NOT RED ) AND YOU CAN USE YOUR 800K FLOPPY DRIVE , WILL WORK AS 400K DIRVE NO PROBLEM. OR IF YOUR CABLE HAS A RED STRIPE, MAKE SURE TO CUT WIRES 9 AND 20, EMULATING A YELLOW STRIPED CABLE.
