Dumb PowerPC question
mloret
Hello! I just obtained a Performa 6300CD! Everything seems to work including the floppy, HD and CD-ROM. The computer came to me with no system installed on the HD so I used a Legacy Disk Image stored on my BlueSCSI to install a version of OS 8 on it. Not bad! However, I read that it will also run OS 9 which isn’t on my legacy restore disk. Im not sure what is the best way to get OS 9 on this thing. Should I find an install disk image in Macintosh garden and burn it on to a CD? Or could I put the same image on the bluescsi? If I did this would I need to save it as an HDA? I would prefer to install on to the build in HD rather than using my bluescsi as the HD. Any advice is appreciated.
volvo242gt
I'd probably burn a CD of 9.0, then update it to 9.0.4/9.1, etc... That'll be simplest. With the OS 9 Helper patch, it should be able to use 9.2.2. I did that on my old 7500/100.
mdeverhart
I’d (mostly) second that recommendation. Find an ISO of one of the retail OS 9 releases (I found 9.0.4 pretty easily, I think there’s a 9.1 or 9.2 out there as well). I’d avoid the 9.2.2 “universal” installers that are out there - as far as I know, Apple never released a 9.2.2 retail CD, mostly they were machine specific disks.
Whatever you find, burn it to a CD, boot off the CD, and install it on whichever drive you like.
volvo242gt
Yeah, to get to 9.2.2, you have to install 9.2 with the OS 9 Helper patch on the installer for that version, then, do the same with 9.2.1 and 9.2.2 to get all the way.
Cory5412
Daring Pioneer of the Future
Staff member
6300 should run Mac OS 9. They don't officially run 9.2.2, or even 9.2.1, so what I'd do is get a retail 9.0.4 or 9.1 CD and just use that. I've got a few EN-US images here: http://vtools.68kmla.org/~/coryw/iso-temp/ - these were ripped on windows, anything like imgburn should burn 'em fine.
As you're trying different things, I'd say look at 7.6.1 and 8.1 for this machine, they should have a decent mix of functionality/features and still running well on that hardware.
Though, trying different things and deciding what you like is also part of the fun!
EDIT: Looks like in the other thread someone was able to get an OS 9 CD for you, great to hear it!
