Does the DP G4 800mhz Quicksilver use thermal pads or paste?
9646gt
As I go through this system I'd like to replace the thermal paste if it uses it. But it seems like I saw somewhere that some G4s used thermal pads? Is there a guide for removal of the CPU card and heatsink?
Does a pad need to be used if you just replace it with thermal paste? I did that in my Pismo and it seems to be working fine 😛
alectrona2988
they use these weird stick on thermal sheets cut into smaller pieces, but thermal paste can be used to replace it. i normally do this with all the machines i get.
