Disable Built-In Ethernet on Centris 650
Is there a way to disable my built-in Ethernet?
I want to play around with the PiSCSI Device supporting a Dayna SCSI/Link driver but the Dayna docs says you can’t have another Ethernet device installed.
I'd imagine just test it and see what happens, there is a good chance it doesn't actually matter.
robin-fo
I don‘t think you need to do. Just switch connections in the corresponding control panels to Alternative Ethernet or so. Maybe they mean „no other DaynaPort Ethernet device“ which would be true.
