So I was able to get an ISO of codewarrior onto my PB190... and as soon as I mounted the disk with the Virtual CD/DVD-ROM Utility I get a popup saying that it doesn't run on 68k...
Now it appears that the bundled MPW works fine... however the the Codewarrior IDE 4.0 itself does not?
Any comments on that? Everything I have read online says that it runs on 68k.... if that is not the case I may just grab 4.0. Or perhaps it would be possible to use the older IDE version with the newer tools?
Also I have switched my PB190 over to an 8Gb CF card internally.... all one partition which works nicely on MacOS 8.0
