CF card in my 9600
waynestewart
I’ve been mostly using a 9600 running 9.2.2 for a few older games. Quite often when it came to a save or a reload, I’d have an annoying wait while the drive spun up.
I had a generic ATA to CF adapter kicking around so I thought I’d see about using it. I tried connecting it as a second drive on the PC133 card but the system would freeze during bootup. Didn’t have any luck adding it to any of the SCSI to ATA adapters I have. Either it'd freeze or wouldn't be recognized. I had some PC100 cards so I put the adapter on it’s own card and it worked like a charm. Copied the whole boot drive over to it. It was a little faster booting than the 80gb on the pc133 card but not hugely. Still, no extra noise and no spin up time.
Byrd
Would you mind posting a link of the generic PCI CF card that you used? Thanks.
A silent, cheap and fast-ish solid state drive would be handy in many Macs with a spare PCI slot.
MacJunky
I have two of that model, they work for my desktop uses and have never caused issues. Got one in my 286 at the moment. :p
BTW, what ATA100 and ATA133 PCI cards are you using?
waynestewart
They're both Sonnet cards.
A while back I used to get a lot of free Macs from a local shop. Actually truckloads. These cards and a lot of others were in those machines. Unfortunately I pretty much lost touch with the shop. These miserable little kids decided that they needed most of my spare time. I wasn't smart enough to run away, now I'm trapped.
waynestewart
Tried the CF adapter on the Sonnet ATA 133 card and couldn’t get the 9600 to boot. So I decided to remove the ATA 133 card and try the ATA 100 card with CF in slot one. It did boot slightly faster there. Since I have boot times, with the same 9.2.2 system copied over to all the drives.
18gb on the built-in SCSI boots in 115 sec
80gb on Sonnet ATA 133 in slot 1 boots in 94 sec
4gb CF on Sonnet ATA 100 in slot 1 boots in 83 sec
Currently has 400mhz G3 with maxed out RAM
