By now you will have a clear understanding of why eyewitness accounts at the accident scene can vary so much. Let me confuse the issue further. A Torx-15 driverwith at least an 8" shank is indispensable. That's a given, and part of Apple's then closed-box philosophy about its 'household appliance'.
Cracking the case, or separating bucket from bezel, needs no force, no pounding, no damage to the rebate around the bucket's opening. Nothing is more convenient than a decent case cracker. The best kind consists of a 1.5" metal disc with a diametrical hard plastic bar that fits the case 'groove', attached perpendicularly to a shank that is then cranked 90° to a 10" shaft ending in a Torx-15 bit.
In the absence of a cracker, remove the bottom screws entirely. Note their colour, so that you can replace the dark screws at the bottom and the bright screws at the top of the bucket. Loosen the top screws two turns each. Place the Mac, face down, on a soft surface. Hold the bucket by the handle, and alternately press the top screws with the Torx driver to crack the joint and begin to separate the bezel from the bucket. Slacken the screws and repeat the process until the screws are completely free of the bezel. Done. And you didn't need to mar the case joint by insertion of anything into the groove.
de
