bus errors?
Richard
Banned
I have a Quadra 700 here that constantly gets bus errors at startup, right before it would load extensions. Often though, this does not happen. The ratio is about 50/50 if I had to estimate. Once, I even got a Sad Mac that translated to a bus error. Bus errors mean trying to access memory that does not exist. What would cause this?
Gil
I remember I got that a lot with my Performa 578. I washed the motherboard, and it went away. Could be cap related, although there are other possibilities.
Richard
Banned
So this could possibly indicate that the Quadra has a finite life, is mortal, and will die from dead leaked capacitors someday (unless they are replaced)?
Scott Baret
Try installing a fresh copy of the system first. I've found bus errors and address errors to occur frequently when software is corrupt (system or otherwise).
