BlueSCSI Questions for Mac Plus
pfuentes69
I'm quite sure Apple HD SC will not work.
I suggest you just try to mount the image I sent with Lido or similar.
silvi89UD
Hi I've been tried but it's nothing to do....I''ve been search on the net what can I do but nothing, the plus refuses to recognise the drive......
silvi89UD
and...if I try to create 2 partitions: one exfat 20Mb with a bank .hda image and the second in another format that is not recognised by The plus ( HFS+ for example) , do u think that Apple SC HD Setup will try to initialise only the 20Mb partition??
pfuentes69
The BlueSCSI doesn't work with partitions. You should have a single partition for the whole card and put your HDA files there. Each file will be recognised as a hard disk (or CD).
And as I said, Apple SC HD should not be used.
What happens when you list the SCSI drives with Lido?
silvi89UD
Hy! Ok, not partitions! No, I haven’t had time to try with LIDo, I will try tomorrow!
silvi89UD
I'm sorry but I think I gonna crazy....I've been download the Lido app.But I can't charge it on basilisk app..not even if I try to change extension in. .iso;.dsk;.img......
pfuentes69
Hello,
the idea is to run Lido in the Plus, so you'd have to copy it to a floppy.
Did you try to reformat the card with a single partition and copy the HDA there?
In one of the rest replies other folk pointed you to some pre-made images that you can use.
silvi89UD
Ok, so I’ve been tried some times with a single partition but nothing…. Maybe tomorrow I try with another pre-made image…. But… I was thinking… and if the problem is that I haven’t soldering the diode yet?
silvi89UD
Hi i have some news I've soldered the diode....I've been tried some times and....it works with system 5 but....a message appears that's it's not enough space on rom disk. If I click on Macintosh Finder I have a lot of memory free in Finder but the system seems full....I have also try to install from floppy Italian version of system 5 but a message appears that I have to set the Apple HD Sc as run application. I set it and restart, the same message appears....do u have any idea???
silvi89UD
It works!!!!!!!!!!!!!! but there's only one problem. when the plus starts, a message that there's not enough space on rom disk appears. I can work, and made some operations. why this message appears?
pfuentes69
enough space in rom disk... I never saw this before... Could you post a photo of the error? I'm very curious about it!
pfuentes69
Interesting... how many images you have now in the BlueSCSI? Could it be that some of these images is named "ROM Disk".
The other option I can imagine is that you have a ROMinator in your Plus...
silvi89UD
I have Only one image with System 5 ! i’ve bene format the SD before copying the image .hda and a fine…??.ini ( I don’t remember the name). What is rominator??
pfuentes69
ROMinator is an special ROM that has some possibilities, such as a ROM disk
if you have one, you'd see a message in your Mac proposing you to boot from the ROM disk, and the happy Mac icon shown at boot changes to a "pirate" Mac
silvi89UD
Ok, I understand! But not…. I’ve been copy all files from my original floppys and create the image, nothing else. 🤷🏻‍♂️🤷🏻‍♂️🤷🏻‍♂️
