TheMacGuy
I'm not sure if anyone remembers this, but my 800k drive in my 512kE has seised up somewhere in the eject mechanism. The floppy drive works, but produces a loud buzz. The emergency eject will move the drive up and down, but the disk won't pop out. I have heard that doing
will fix the problem, but what lubricant should I use? I have heard liquid teflon, others white grease (like the 68kMLA Wiki says). I was wondering, which one has turned out the best without damaging the drive? Also, is there anything else I should check while in there?
Also, the external 800k I bought has a problem where it will try to mount the disk with part of the disk still sticking out (about an inch of the disk sticking out). I have to use another object to shove the floppy in far enough to get it to get it on the header for reading. Sometimes, the disk is in there, but not all the way, so the computer will say its not readable and to initialize it, but the initialization will fail, so if I eject the disk, and push it all the way in, it will mount. Any ideas what the problem is? The eject motor is a little weak too. Not sure if the disk is sticking on some of the plastic, or if the motor is just getting old.
Please, anyone with ideas, please respond! I'm going to the hardware store tomorrow to get the final products for the repair, and would like to get it done tomorrow, since I have a free day.
Thanks!
Thanks!
