What speed processor do you have? Halo ran OK on my 1.25GHz G4 Mac Mini, which has a Radeon 9200 (similar performance to the 9000).Seeing how varied the responses are, I’ll refine things: I’ve got a Radeon 9000 currently with 64 MB. Playing Halo isn’t exactly the speediest. I was seeing if there was maybe a 128 version or something to help out. I’d rather not get the cards that I have to modify or anything like that…though “getting separate power” could be ok.
ADC is an abomination that should never have happened.
I think the ADC power pins moved between eras, so I'm not sure that a G5 card would work in an older G4 out the box. Not sure of the details, but something to check up on. I think the transition aligns with the move from 2x to 4x AGP, or is it 4x and 8x?
Not my era of machines, I've never run one regularly.
If you just want OSX and want to use the G4, then a 1.6GHz upgrade and a Radeon 9800 Pro (G4 version) might sort your issueIt runs ok, reducing the resolution is probably the best I can do, I was just seeing what else maybe could help. It’s a dual 1 GHz QuickSilver, 1 GB RAM. Also, I forgot to mention earlier, OS 9 isn’t important - only games I’d be playing are on X. I guess if I really want a bang-up Halo experience, I should set up my dads G5 .
I appreciate all the info thus far, I didn’t have any concept of graphics around this era.
The cheap cards at the moment seem to be the Radeon 9600s. They're about 30% faster than your 9000 in PC fill rate tests (not an ideal comparison, but it should be vaguely representative). But only half the speed of a 9800. The main advantage is you can find them for less than $30. Perhaps worth it as a backup card anyway.I suppose I don’t “need” ADC, it’s just convenient since I have cinema displays. On the flip side, two of them have the adapters as well so I could use regular DVI.
I think there is more than one version. The one I linked says AGP 2x / 4x in the box, and the one I own is from a G4 (genuine Mac card, bought as an upgrade).The Mac edition 9800 Pro is an AGP Pro card that gets power from the extra slots and is meant for G5 AGP towers and won't work in a G4.
The Mac edition 9800 Pro is an AGP Pro card that gets power from the extra slots and is meant for G5 AGP towers and won't work in a G4. You can mod a PC 9800 but good luck finding a working unit that doesn't cost a bunch since PC gamers lust after them.
