Beige G3 motherboard in 8600 case?
Quadraman
Since one of the biggest complaints about the beige G3 is how much smaller the case is compared to the 8600/9600, I wondered if anyone had mounted a G3 motherboard into the older, taller case to be able to add more drives to their G3.
alk
Have you looked around on www.accelerateyourmac.com? Also, I'm pretty sure this topic has been discussed at length here and at AppleFritter. Short answer is that it is not a drop-in replacement.
Peace,
Drew
Maccess
There are lots of places to add extra drives in a Desktop G3:
-Where the Zip drive is and above that (make a special bracket)
-Where the floppy drive is, another Optical drive can be placed there if the front of the case is modified. You'd switch to a USB floppy since the internal floppy isn't supported by Mac OS X.
-Along the floor, where the internal drive is located, you could get a smaller drive and place two in there.
The problem is that the power supply can't handle all those drives. You could use a PC power supply: The conversion is reportedly easy and also involves moving a jumper on the G3 motherboard.
LCGuy
LC Doctor/Hot Rodder
I'd like to confirm what alk said...it is possible, no doubt, but its also very difficult, as the 8600 is based on a Tsunami form factor, whereas the G3 is based on a PC ATX form factor. It is possible most likely, but it would require SERIOUS modding.
Maccess: You most certainly can use any standard PC ATX power supply on a G3 very easily...the power supply just drops in, you don't have to cut any wires or mod it or anything, and there is a jumper on the mobo that has two positions: "MAC" and "PS2". For operation on an ATX PSU, move it to "PS2".
Quadraman
Is the 390W PSU from a Kansas motherboard machine usable?
Maccess
Can you point me to a page for exactly that mod? I'd like to read some documentation about it before actually doing it.
