theirongiant
I have a beige G3 233MHz (Rev A? ROM $77D.40F2) that I picked up from someone locally. It had 96 MB of RAM, so I decided to upgrade it and install OS 9.0.4.
When it has less RAM, the computer chimes and shows a black screen for maybe 10 seconds before going gray, then showing the happy Mac.
I sourced 768 MB of RAM (3x256 low profile DIMMs) and installed them one at a time. With 256 MB of RAM, there is no picture for about 40 seconds. With 768 MB of RAM installed, this delay extends to about a minute and a half.
The following cards are installed (removing them had no effect):
- PERCH: Standard audio card
- PCI: USB+FW combo card with TI & NEC chips (featured elsewhere on this forum)
- PCI: ATI Rage 128 (sourced from a blue & white G3)
I realize that all computers have a RAM test as part of their POST routine.
Is this duration of black screen normal for a G3 beige Mac doing a power-on self test?
I ran some utility recently that shows the PRAM hasn't been reset since 1998, and the 3.6V lithium battery is still working and keeping time. Would resetting the PRAM change this behavior at all?
Another colleague recommended that I press Opt-Cmd while clicking the Memory control panel. This reveals a hidden option to disable "Startup Memory Tests." I've turned it off, but it does nothing.
Also, if I restart the Mac (instead of shutting down), the following sequence occurs:
1. Hard drive spins down
2. Monitor goes black
3. Boot chime
4. Black for X seconds
5. Gray screen
6. Hard drive spins up
7. Happy Mac icon, boot
Thanks!
3. Boot chime
5. Gray screen
Thanks!
