I recently picked up a IIGS and the keyboard it came with had alps orange switches. Well several of the keys didn't respond well (maybe about 6 keys) sprayed the switches out with deoxit and finally after several dozen pushes they started responding pretty consistantly. However the "4" key would not respond whatsoever. I desoldered the key switch and took it apart. I can't really find anything faulty with this, but granted I know nothing about this switch. If I hook an ohmmeter to the terminals I will get a close circuit when i press the middle plastic part, but trying to get it to work with the switch just seems a lost cause. Didn't know if someone had run into this before or not, or worse case, if someone knew a source for a replacement switch.
Thanks.
Thanks.
