mcdermd
I'm leaning towards having a bad card because I think I'm doing everything correctly.
I have an Apple II SCSI Card (not the Hi Speed Card, just the regular one) #607-0291-A with a Rev C ROM on it.
The Apple IIe has a Disk II controller in slot 6 and a Super Serial Card II in slot 3. I put the SCSI card into my Apple IIe in slot 5. I plug in a 20SC drive into the DB25 connection. The 20SC has a passive terminator on it and is setup as SCSI ID 0. When I go to boot, it starts to start ProDOS from the Drive 1 Floppy (Apple SCSI Card Utilities) and then hangs. The floppy stops accessing on the initial ProDOS screen. It's like it's waiting on the SCSI. If I remove the SC20, it still hangs. If I remove the SCSI card, all is fine.
Having the same sorts of issues on an Apple IIgs with the same card.
Any ideas? Just a bad card?
