Anyone able to make an Apple SCSI Terminator II (Black) - M5871G/A?
TimHD
For the benefit of those with Mac IIfx's (or NTX printers) out there that having issues getting external SCSI devices to work because they can't locate the incredibly rare "Black" Apple SCSI Terminators II's - I was wondering if the linked Apple Tech notes might be of interest to someone here who may be able to make these. The linked Apple's Developer Tech Note on SCSI Termination outlines the differences between the standard (Grey) and Mac IIfx/NTX (Black) Terminator II's (and has a pretty bad set of Sarah Conner jokes).
This Technical Note discusses SCSI termination on the Macintosh, including the new rules of termination that are necessary with the advent of the high-speed Macintosh IIfx.
Why Is the Terminator After Sarah Connor?
Old (Grey) SCSI Terminator:
New (Black) SCSI Terminator II:
How hard would it be to create one of these and sell them to IIfx (NTX) users out there?
Link to archived notes: http://www.fenestrated.net/mirrors/Apple%20Technotes%20(As%20of%202002)/dv/dv_15.html
Byrd
Have you tried with a normal terminator?  I'm fixing up 3 x IIfx machines at present, and can honestly say I've never encountered any issues running a single SCSI device like a SCSI HD or CD-ROM drive, using a standard terminator.
TimHD
I find that if I attach an external SCSI with normal terminator, I lose the internal SCSI HDD (not a SCSI ID issue btw) unless I use my Iomega drive as the last device in the chain (which seems to work better), hence I think I need one of these black connectors to make it stable and work.
CelGen
Oh my god. Is the myth about the damn black terminator STILL floating around? This was debunked years ago.
TimHD
I think the myth is because it's not needed on most later iifx's (as it seems from some old comments I have seen), but early models had issues. Happy to be proven wrong but i can't get ext SCSI working without say an Iomega termination whereas other passive grey SCSI terminators don't work.
Scott Squires
Have you tried using a regular active terminator? Try that first before trying to replicate Apple's cheap shortcut.
TimHD
For future reference: Apple Support doc on these.
https://support.apple.com/kb/TA42169
Macintosh IIfx: Termination (4/95)
This article contains information about Macintosh IIfx termination and external terminators.
This article has been archived and is no longer updated by Apple.
There have been 4 different external terminators distributed by Apple. Two are identical except for the part number.
Part Number Description
590-0304 The original terminator.
590-0695-A Replaces 590-0304. This is the new PLATINUM terminator
590-0695-B
& 590-0705 These are BLACK and are identical, except for the part
. number. Apple built approximately 10,000 having the part
. number 590-0695-B; later manufactured black terminators
. are numbered 590-0705. One black terminator ships with
. every revenue Macintosh IIfx, but can be ordered
. separately from Service using part number 590-0705.
. Note:
. Only 1 black terminator is ever needed at a time; more
. details are below. These black terminators are
. officially called the Apple SCSI Cable Terminator II.
The Other Two Macintosh IIfx SCSI Bus Components
Internal SCSI Termination Block
The Internal SCSI Termination Block provides internal termination resistance for Macintosh IIfx systems WITHOUT INTERNAL HARD DRIVES. All Macintosh IIfx computers that shipped without internal hard drives had the Internal SCSI Termination Block installed. This component plugs into the Internal SCSI Filter and it looks like a "T", with a 50-pin female connector on the bottom.
The Internal SCSI Filter provides termination capacitance for internal Macintosh IIfx hard drives that shipped prior to March 19, 1990 or any third-party hard drives. After that date, Apple hard disk drives shipping in the Macintosh IIfx contained the proper termination capacitance. The filter has a 50-pin female connector on one end and a 50-pin male connector on the other. When connected to an internal drive the drive cable should be connected directly into the logic board and plug the Internal SCSI Filter block between the drive cable and the 50-pin connector on the hard drive. When there is no hard drive the SCSI Filter is connected to the logic board, and the Internal SCSI Termination Block is connected to the filter.
All Macintosh IIfx computers that shipped without internal hard drives had the Internal SCSI Filter and the Internal SCSI Termination Block installed. When you add a third-party drive remove the Internal SCSI Termination Block, but leave the Internal SCSI Filter connected to the logic board. Termination needs to be provided by the resistors on the internal third-party drive.
Determining What Terminators to Use and When
No External SCSI devices Connected
Termination is provided by either the internal hard disk, or by the Internal SCSI Termination Block.
With a Third-party Internal Drive
The third-party drive should be internally terminated. Plug the drive cable directly into the logic board and plug the Internal SCSI Filter block between the drive cable and the 50-pin connector on the hard drive (Cable and filter order is important for this to terminate correctly). The Internal SCSI Termination Block needs to be removed (it looks like a "T"). Plug the drive cable directly into the logic board and plug the Internal SCSI Filter block between the drive cable and the 50-pin connector on the hard drive.
With Any External SCSI Devices Connected
Use only ONE black terminator at the end of the SCSI chain. Make sure that all built-in terminators are removed from external third-party SCSI devices (Apple's external SCSI devices do not contain internal terminators).
NOTE:
A flyer in the Macintosh IIfx Finished Goods box instructs customers to
return self-terminating SCSI devices to the Service Provider to disable the termination. Removing the termination can be performed by the user in some circumstances--a user should refer to the owners manual or check with the manufacturer if they are uncertain.
WARNING:
Under no circumstances should you use more than one black Apple SCSI Cable Terminator II on any external SCSI chain. This may damage the logic board or whatever device is providing termination power.
With An Internal Disk Drive And External SCSI Device
Both the internal SCSI drive and the last SCSI device in the external SCSI chain need termination, and you need to plug the Internal SCSI Filter block between the drive cable and the 50-pin connector on the hard drive.
Why Is There A New Black Terminator For The Macintosh IIfx?
One of the features of the Macintosh IIfx is a new SCSI chip that provides SCSI data transfer rates up to 3MB per second, faster than any earlier Macintosh systems. To achieve these transfer rates, components on the Macintosh IIfx logic board are smaller and faster, this makes them more susceptible to signal reflections on the cable. The new terminator adds the filter capacitors and changes the resistor values for some of the signals to reduce the reflections.
How Can Third-party Drives Take Advantage Of The Higher Scsi Throughput?
Any SCSI hard drive that can sustain transfer rates above 1.25MBps will operate faster on a Macintosh IIfx. No Apple hard drive, including the HD160 SC, takes advantage of this higher transfer rate.
What To Do With Less Common System Configurations
In some remote cases someone might remove the internal drive from a Macintosh IIfx they will not have the correct internal termination. In this situation, you should order and install a Internal SCSI Termination Block (Apple Service Part #590-4515) and Internal SCSI Filter (Apple Service Part #590-4516), and use the black terminator if you have any external drives; however, if you don't have access to an internal termination block, you can connect use the new platinum terminator (590-0695-A on the terminator) to the beginning of the SCSI chain and, as always, connect the black terminator at the end of the chain. Again, what is preferred is to order the Internal SCSI Filter from service.
Article Change History:
13 Apr 1995 - Added information on having internal and external drives.
CelGen
So in other words, Apple's own terminators are faulty by not adhering to the standard (which is already broken because they used that stupid 25 pin connection) and using any other third party terminator will suffice.
