800k floppy read-write with Greaseweazel + FluxEngine = Success!
Andrew
Hello all,
just wanted to say I had success in reading and writing 800k disks for my mac.
Of course credits go to the developers of the above programs.
I am more than happy to make a simple guide if there is interest.
Andrew
I used what Greaseweazel project refers to as the F1 "direct-connection" board. It is a STM32F103C8T6 chip also known as bluepill. However, I was not able to source this blue pill board locally, so I used another one (no name) which has the same chip. The pinouts are located elsewhere on the board, but the functionality is the same.
I did not use the recommended firmware upgrade process (https://github.com/keirf/Greaseweazle/wiki/Firmware-Programming) because I did not have the special ST link programmer. However I was able to program it via a generic usb serial (3.3V) adapter I had, together with a programmer called STM32CubeProgrammer.
Also, through trial and error I found out that the latest g/w firmware 24 does not work with fluxengine, instead we need to use 2.2.
At this point I am trying to figure out how to write custom mini vmac images, as these do not have a header, and fluxengine is complaining about this. Diskcopy 4.2 images that I downloaded from the internet worked fine
sambapati87
Just want to say that's great! I've always known it to be "impossible" to write 800k floppies for Mac from anything but another Mac drive.
Torbar
I ordered some PCBs for this project(rather than doing the direct wiring method) which should be here within the next week or 2, so if anyone is interested in a blank PCB or 2 for a few bucks shipped(within the US), let me know
erichelgeson
Got my boards from @Torbar
and got it setup. Seems to read the few disks I tried fine, will be trying a few bad disks I couldn't read in my Mac and see if I can salvage the files.
Andrew
That's great. I hope you get good results. I found that the Mac drive is better at reading. E.g. when reading some disks with this setup I might get a few bad sectors, whereas the Mac drive can make an image just fine.
But nevertheless it gives more choices which is great.
erichelgeson
Oh, I was not aware of this - for connecting a mac floppy do you need a straight through cable or with the twist? how does power work?
Had good results reading 1.44 disks, but no 800k's have worked so far in fluxengine or gw - though I've only spent a few minutes on it so far.
erichelgeson
Sorry I meant a Mac floppy drive operating in an actual Mac!
Ahh! makes more sense :) what command do you use to read 800k disks? Also I have a bunch of notes i'll post here later as setup is not "simple" - just a lot of things to setup
Andrew
It is the same command as 1.44MB disks. I think it reads the right format from the diskcopy header.
The command is
fluxengine write mac -i mac.diskcopy
and relevant information can be found here http://cowlark.com/fluxengine/doc/disk-macintosh.html
Andrew
@erichelgeson The label on it says Sony, model: MPF820-E. I pulled it off of an old computer.
do you get an error? Do you have problem reading or writing?
erichelgeson
I have a good 800k disk I formatted on my real mac and put a file or two on to test. I just get a bunch of failures to read tracks - same disk works fine in a real mac. Reading 1.44 disks are fine - recovered a few things already. Someone on the forum mentioned this model had issues with 800k disks too. The Sony & Samsung seem to be validated working.
Andrew
Make sure you tape the hole if the disk is hd.
also, i. The beginning i also had same issues like you, then I cleaned the heads of the floppy, and steadily the bad sector problem started to go away
I've started doing this for archiving 800k floppies now; can confirm that I've had luck with a Sony MPF920 (just out of an old PC) and a greaseweazle f7. Going to stick it in an external USB enclosure now... Thankyou @Andrew for passing this technique on :)
