Franklinstein
I pulled apart a 520 the other day. Indeed there are many clock crystals in the system: at least four on the logic board for various subsystems and one on the processor card to clock the processor/processor bus. The processor card crystal runs at 1/2 bus speed, so it's 12.5MHz in my 25MHz-bus example. So changing bus speed to 33MHz would need a 16.7MHz crystal, or to 40MHz a 20MHz crystal. Overclocking is not a good idea, as mentioned, because these things run warm as it is and there's no room for additional cooling (unless perhaps the modem parts are removed and maybe a tiny fan could be fitted to the phone jack port).
I don't think there's a difference between the other 5x0 series and the 550's ROM; I think it's just that the QFP 68040 is apparently NLA from new (and as we discovered the modern 68040V is a low-voltage FPU-less design) so I have no idea where you'd get one.
