Thank you, trag, for your response. You may be familiar with the IIci, in which header W1 at (roughly) H7 is marked ROM SELECT. Because there is/never was a ROM SIMM for the IIci, the jumper must be in place permanently to use the soldered-in ROM.
Let's see. I explored that jumper when I was working with Gamba on the IIci ROM for SE/30 project. I remember in a general way what it does, but I do not remember explicitly what it is connected to, unfortunately.
In general, what that jumper does is keep the Chip Select (CE_) pins on the soldered-in ROM connected to ground.
Specifically, I think that if you remove the jumper and check the continuity, you'll find that one pin is tied fairly directly to GND--either 0 ohms or a few hundred ohms, and the other pin is connected to +5 much more weakly 500 ohms to 10K ohms.
You will also find that the side which is tied weakly to +5 is also tied directly to all the CE_ pins on the soldered-in ROM chips. I think that is ROM pin 22 (with the notch on the chip towards you, pin 1 is the bottom right-hand pin, numbering goes counter-clockwise from there).
When you install a ROM SIMM, you remove the jumper and all the Chip Enable pins on the soldered-in ROM are pulled high (or rather, no longer pulled low), which is Inactive for the CE_ signal, so all those chips go dormant.
Later machines, such as the early PCI Macs (x500, x600) use a much more elegant system. On those machine, the CE_ pins of the soldered-in ROM are routed to one of the pins on the ROM DIMM. They are also weakly tied to GND on the motherboard. So, under ordinary circumstances, the soldered-in ROMs' CE_ pins are tied to GND, held low and therefore active.
When you install the ROM DIMM, there is a circuit on the DIMM which ties the CE_ pins of the soldered-in ROM (remember those signals are routed to a pin on the DIMM) to 5V, therefore pulling the CE_ pins high and disabling the soldered-in ROM.
This IIfx behaves just as a IIci without its ROM-select jumper does. No PSU activity. No other startup activity of any kind. No voltages appear at the PSU/MLB connector, and especially not a 5V TRKL. Yet the PSU fuses are intact.de
I believe that you should get start up activity even without a ROM. Most Macs will power up and do nothing even if the CPU is removed.
However, are you aware that the IIfx requires a working battery to power on? I can't remember which one it is, or maybe it is both. But at least one of the two and maybe both need to be good batteries. If you were already aware of that I apologize, but for now I'm going to rest with that bit of advice.
