190cs: fuse location??
desertrout
desertrout
So, here's what I'm trying to troubleshoot: the machine boots immediately after plugging in the PSU but with no video. The machine apparently continues to boot to desktop, but there is nothing on the screen. I can adjust the backlight, adjusting contrast makes no apparent difference.
I've performed the typical PRAM / power manager reset, but no change. Battery is dead (of course), but symptoms are the same whether it's in or out. Symptoms are also the same whether the RAM card or floppy drive or hard drive are installed or not.
I've seen this same behaviour in a 1xx series PB when the fuse was blown, so that's where my attention is focused. The repair manual for the 190/5300 series suggests checking the fuse on the logic board, but I can't find it and I kinda don't think there is one... but this is the 'newest' logic board I've ever worked on, so could just be ot recognizing it.
Recapping both the logic board and display boards is on my TODO list, but this machine was *reputedly* working before it was shipped to me, so I'm scratching my head.
desertrout
Alright, made a new PRAM battery and that has cleared up the auto-start issue and other power management quirks. Seems to be behaving normally on that front. Still no video though, despite many (many, many) minute-long power manager resets and PRAM zaps (I heard sometimes it take a crazy number of tries)..... video cable seems ok (not verified), but if a recap doesn't make a difference then toning it out will be my next step.
