Ge Psu issues
imactheknife
Had a ge iici psu that worked. Recapped it, and it worked fine, for a bit. Then it wouldnt shut down properly. So took apart and checked my solder, then it did nothing lol. Checked it again, now turns on, then off immediately.
I decided to recap my other ge psu and it works fine. While recapping the 2nd one, i noticed a couple of caps that were 1000uf 25v and on the first psu i had made them 2200uf 25v. So i fixed other psu and they both worked perfectly when i went to bed.
This morning, the original psu i recapped is back to turn on then off again immediately. Any ideas??
