Thank you. I already have it. Got it lot in with other cards pretty cheap.It's an eMachines video card. They made combined video and ethernet cards, on some the ethernet was only available with an optional daughter card, this is one of those cards without the option.
So, just a video card. Should have accelerated graphics. My experience with eMachines cards is that the specs are quite good, they tend to do millions of colours and be accelerated, but the drivers are a little flakey.
If it's cheap, jump on it, if it is... A more than a Radius PrecisionColor XK, get the PrecisionColor instead.
Which Mac do you recommend I use this in? Iifx?It's an eMachines video card. They made combined video and ethernet cards, on some the ethernet was only available with an optional daughter card, this is one of those cards without the option.
What do you have in your IIfx at the moment?Which Mac do you recommend I use this in? Iifx?
I am not at home. But here is the screenshot from my iifx listing.What do you have in your IIfx at the moment?
Yeah, it is a step up from that card. That card only does 256 colours at 640*480 and isn't accelerated.I am not at home. But here is the screenshot from my iifx listing.
Prefect. Thank you.Yeah, it is a step up from that card. That card only does 256 colours at 640*480 and isn't accelerated.
. I mean I looked up how much pins aui had and it somehow corresponded
