Mac plus Issue
My mac plus screen is too bright and has bright lines going across the screen. I tried adjusting the controls on the back, and the brightness, but it didn’t get rid of it. How can I fix it? The pictures below kinda show it, but I couldn’t get the camera to get a good picture of the CRT.
Byrd
I'd look first to the CRT adjustment pots, squirt some deoxit or electronic solvent cleaner/lube in and around these.
I powered it on today, and now it won’t even make the bong, the screen is just garbled. Could this be caused by bad caps on the analog board?
goerz
I went and disconnected the LB and plugged it back in and now it is back to what was happening in the above pictures.
I have a Mac Plus with the same issue. I read on the Dead Mac Scrolls that I should replace resistor R5 (470K ohm, 0.25 watt, 5%) on the analog board. I tested mine and it's 420K ohm: maybe it doesn't mean much, but the drop in resistance is still more than twice its 5 % tolerance. Maybe we found the culprit.
falen6
i had the same problem with an old SE
recapped the analog board think it would fix it but it is exactly the same
MegaImg
Their is a Brighness controll on the analog board. Use the nob in the front and put it on high, take the case out and adjust the brightness on the analog board until the lines are not visible.
MegaImg
Where is the coIntrol?
In the 512K, you have to take the back out, is in the side of the Analog board. You need a flat Plastic tool. Remember, high Voltage. On the white card board attach to the analog board, you will see the Brightness Adjustment.
I only saw cut-off and voltage on that side, and neither would go low enough to fix it.
goerz
So i swapped R5 with a resistor from a working board and the problem didn't go away. Back to the working bench.
MegaImg
Verify that you don’t have crack soldering points. This is common on this Analog board. Reflow major connector or check with magnification all soldering points for all components.
For me that resistor doesn’t have a reading. The legs are also corroded.
MegaImg
THis is the 512K, but must be similar, you can see top left the Britghness Adjustmen on the analoig board.
MegaImg
If you tap it and nothing, I have to agree to check / replace resistor R5 (470K, 1/4 %-watt, 5%).
