I see, but I want to set it up locally on the machine to make sure everything is optimal. I tried to format it with Apple HD SC Setup instead of partitioning it, now and I got an "address error" crash. I ran a full RAM test on this thing just now, and it passed. Also ran a full disk test with Apple Personal Diagnostics, and it passed too. Maybe BlueSCSI v2 Desktop is not that compatible with Macintosh SE using System 6 Apple HD SC Setup?
I would only want to sell it locally in Norway, sorry. Also it's not like I would sell it for cheap, this thing is probably worth $100. It has 68030 25MHz (compatible with up to 33MHz), 1-waitstate RAM (configured from 2 to 1 waitstates), and onboard video with VRAM.
I'll have a go at it on one of my SE's, as good a reason as any to test my v2 BlueSCSI!
I understand you trying to install the"correct" way, but for troubleshooting purposes, I would try with a bog standard (English) 6.08 image, you can find them online and stick it on an SD card, see if that boots.
If it does, then you know it's not the BlueSCSI or SD card, but rather something with the installation procedure.
Would Belgium be Local enough
? Love to get one of those cards, don't see them much here.
Oh, and I guess it's worth well over 100 €!
