8100/80AV Unstable
Qrani
Ok, I tried my other CD-ROM from my PowerMac 7500 but connected to the other SCSI BUS, and it booted System 7.1.2 just fine. I then tried the Mac OS 9.0.4 CD and it failed to boot, but doing it again with extensions off got it to boot.
Qrani
Just tried the other CD-ROM drive also connected to the other SCSI bus, and it booted the 9.0.4 CD just fine, didn't even have to disable extensions... So that SCSI bus may be broken. I guess it could be the cable, but I would assume it's not.
Qrani
However, I just opened up drive setup in the Mac OS 9.0.4 CD, and it recognizes 7 CD-ROM drives. Maybe my terminator just doesn't work?
capa150
Is the ram the correct RAM type for this mac?
My blue and white G3 was crashing too frequently and randomly. Every 1-4 hours maybe. I did two things that fixed the problem but I don't know which actually solved the problem, ha ha. The first: I bought an official MacOS install CD off ebay. Earlier I had been using a version of MacOS I downloaded from the internet. The second thing is I replaced the four PC133 RAM sticks with a single proper brand new PC100 RAM stick from OWC ($8 new!).
LaPorta
This might sound crazy, and is pure conjecture on my part...but there's the possibility that there could be a power supply related issue. My 8100 had crazy issues: freezing after working for five minutes for no reason, not wanting to recognize RAM, all sorts of weirdness. Could never track down the issue. On a lark, I got a new PSU....and it worked fine. I put a scope on the output of the PSU vs the new PSU....the original had some very fine, low oscillations - basically, the power coming out of it was "dirty." This somehow cause all the havoc that I was having.
Not saying this is your problem, but I know the Delta PSUs in there are temperamental at best to begin with. Maybe look into that too if you can't figure it out.
PC133 works in a PC100 computer, so that specifically wasn't the issue, although perhaps something else wasn't right with the RAM, who knows.
The 133 is basically just the rated speed of the RAM. The B&W requires a minimum of PC100. The beige G3 requires PC66, but I have PC133 in most of mine.
Qrani
Seems like a good opportunity for an ATX conversion.
When I first got the machine I couldn't get it to properly start up, so I tried the power supply from my PowerMac 7500, and it started up that one time, so I thought it was an issue with the PSU. I was gonna do an ATX conversion, got around to measuring the voltages, working on making a connector, etc. But then I tried to use the 7500's PSU again later and it didn't start. Turns out both give perfectly fine voltages, and it was probably an issue with the motherboard. I've been meaning to try it out with the 7500's PSU again, because while I know the 8100's has the correct voltages, that doesn't mean it necessarily is working, especially when being used on the computer.
CC_333
As with @LaPorta 's thought, this might seem a bit off the wall, but have you checked for cracked solder joints at the PSU connector?
It seems like maybe there's an intermittent connection somewhere?
c
Unknown_K
Some machines are picky about chip density which changed going from pc66 to pc100 and pc133 and even within the same spec as time went on.
trag
I saw in your original post, you have the AV version. Are you testing with the AV card installed? An empty PDS slot could cause problems.
On your CDROM drive, is it possible you have all three SCSI ID jumpers installed? It's been a long time but I think I only saw that repeated device when two devices had the same ID. Since you only have two devices and the motherboard ID is fixed at 7, the CDROM would have to be set to 7 to cause a conflict. All three ID jumpers gives 7.
Maybe a little farfetched...
Qrani
Yes the AV card is installed. I need it so I can use a monitor as I don't have one for the HDI-45 port, or an adapter. The CD-ROM drive is set to either a SCSI ID of 1 or 2. I believe the CD-ROM drive only actually has jumpers labeled 0, 1, and 2, so I don't think I could set it to an ID of 7 if I wanted to. And what does the 0 jumper do? No clue. But regardless it works perfectly fine when connected to the other SCSI bus, which the only other device on would be the computer itself, so it's not an issue with jumpers
trag
The jumpers represent different powers of 2 and they're additive. Hence, 0 => 2^0 =1; 1 => 2^1 = 2; 2 => 2^2 = 4.
For example, jumpers on 0 and 2 gives you 1 + 4 = 5, so SCSI ID 5.
Jumpers on 0, 1 and 2 would give you 1 + 2 + 4 = 7.
Some devices actually label the jumpers 1, 2, and 4, instead of 0, 1, and 2, which is a little easier to understand.
