Guidance on music-making
mloret
Hey guys,
I am trying to relive some of my childhood fun fiddling with music software. When I was a kid, I was given an Adlib sound card as well as the software. It was great because it didn't require MIDI and the software (Visual Composter) didn't require any knowledge of music notation. You could literally compose straight out of the box.
I have been trying to replicate some of this magic on my old Apple machines with minimal luck. I started with my Apple IIgs and I decided it might be fun to try to find something for my more powerful (and modern) Macintosh Performa 6300. So far, I haven't had much luck.
So my question is this--can you recommend a software package that includes software instruments, doesn't require MIDI, or a deep knowledge of music composition? I WAS able to load Cubase 5/32 onto the hard drive but my computer doesn't currently have enough RAM to run it. Also tried in Sheepshaver but that was a bust. Any ideas on what software package to use (if any)?
Thank you.
Chopsticks
I was about to say cubase but you've already mentioned it. there's probably similar DAW software such as eMagic Logic etc but the thing is software instruments specially those used in DAW software will tax the cpu but more importantly they need a decent amount of RAM.
there's certainly lots of good software from the day for making music, but a lot of it is MIDI based as the audio production stuff was mostly left in the realm of the professions because the cost of the hardware required was just insane then. it wasn't really until the iMac came out that serious audio production DAWs because realistic for the average home computer and user.
the adlib used as OPL2 chip, its apretty unique sound for a FM-synthesis IC so I can understand the fondness you remember from you childhood. the software you mentioned appeared to just use the standard piano roll setup where you kinda paint and draw the notes you want.. this was and still is the most common way of working with MDI, in fact even software instruments today still use this exact same method for inputing the notes. you see even software instruments typically use midi on the backend to handle the controls and interface etc.
Hopefully someone else on here might know of something I'm not aware of. I grew up with cubase and a lot of other music software and hardware for the Macintosh as my Dad was an academic doing research in music and computers as well as teaching music, the 1990's were a crazy time for audio production, I had a lot of fun growing up that's for sure
There was a built in midi synth in Quicktime. You can use it with early versions of Logic through OMS with a special extension... but the setup isn't trivial and it is 20 years since I've done it. If I get you started hopefully someone has a better memory of the settings.
Not sure what version of Logic to recommend, I was a Cubase Kid (old Cubase didn't work with OMS frustratingly).
OMS is probably included in the Logic installer.
You'll also need Quicktime Instruments installed, if it isn't already.
Chopsticks
a really good resource I've used over the years for classic Mac music production is actually the DAW subform on macos9lives.com
there are a huge number of people there who to this day continue to do music production on pre OS X Mac machines so they're probably a huge amount of information you can read up on there about the software available, how well it runs, and issues and fixes found etc...
might be worth a look
Some stuff from my childhood...
6300 will run this fine :
It will struggle with this :
Happy to see this online at last :
Cubase is another option, but generally works best with a sound module and/or recording live instruments on a PPC603, which wouldn't really have enough grunt to do Virtual Instruments justice.
You might be interested in something like Scream Tracker or Impulse Tracker. Trackers were more popular with Amiga and PC than Mac though.
I believe PlayerPro lets you compose too. Works on 68k and PPC :)
Playing demos on some of my Macs :
